Date/Time: Tue, 26 Nov 2024 23:34:25 +0000
Incompatible Chartbook File
View Count: 222
[2023-10-07 11:53:14] |
User509652 - Posts: 1 |
Hiya, could you please update the .cht files attached to run in the new versions of Sierra Chart. Many thanks |
DOMCHARTBOOKFX.Cht - Attached On 2023-10-07 11:52:30 UTC - Size: 276.18 KB - 235 views Attachment Deleted. |
[2023-10-09 21:07:25] |
John - SC Support - Posts: 36309 |
Follow the instructions at the following link: Chartbooks (Workspaces): Opening Older Chartbooks For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
