Date/Time: Tue, 26 Nov 2024 23:28:06 +0000
Delta bar as candle stick
View Count: 890
[2023-10-06 17:46:39]
User474409 - Posts: 10
Hi
I am trying to draw the bar delta as a histogram under the numbers bars. I have tried the ask volume/bid volume difference study and subgraph reference study. But I want to be able to see it like a candlestick and adjust the width of it.
I am attaching 3 screenshots. I would like to get the end result as shown in the 'expectation' screenshot. The other two are my two attempts
imagesubgraph ref.PNG / V - Attached On 2023-10-06 17:45:51 UTC - Size: 33.21 KB - 200 views
imageask_bid_difference.PNG / V - Attached On 2023-10-06 17:45:58 UTC - Size: 39.34 KB - 166 views
imageexpectation.PNG / V - Attached On 2023-10-06 17:46:03 UTC - Size: 60.53 KB - 178 views
[2023-10-09 15:50:15]
Sierra_Chart Engineering - Posts: 17187
So you will want to use this study:
Ask/Bid Volume Difference Bars
Is the problem that the bars are not wide enough? The candlestick width can be controlled through Graphics Settings Other tab:
Graphics Settings
[2023-10-10 14:37:47]
I want to change the candlestick width of the Ask/Bid Volume Difference Bars study , but the graphic settings seems to only apply to the main price graph
Am I missing something?
[2023-10-10 15:55:03]
John - SC Support - Posts: 36309
The Graphic Setting will apply to all the Candlesticks, including the "Ask/Bid Volume Difference Bars Study". Make sure you are changing the "Candlestick Width %" and that you have not changed the "Ask/Bid Volume Difference Bars" to be displayed as something else.
But there is not a way to change only the width of a single study that is presented as bars. The only control for this is the global settings.
