Date/Time: Wed, 27 Nov 2024 00:37:10 +0000
Heiken-Ashi candles with variable width based on volume
View Count: 368
[2023-10-06 13:31:18] |
n8trading - Posts: 36 |
Wondering if there is a way that I can have Heiken-Ashi candles but with variable width on the bars based on volume? Or I'd be open to an alternative suggestion to being able to easily see volume per candle but with Heiken-Ashi candles. Thank you. |
[2023-10-06 17:30:15] |
Sierra_Chart Engineering - Posts: 17187 |
Yes this is fully supported. You just need to adjust the Graph Draw Type for that study to Candlestick Price Volume Bars: Chart Studies: Subgraphs Tab >> Graph Draw Type This also can be set for the main price graph: Chart Settings: Graph Draw Type (Chart >> Chart Settings >> Bar Period >> Graph Draw Type menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
