Date/Time: Wed, 27 Nov 2024 00:27:18 +0000
Trade simulation not working since symbol changed over for ES
View Count: 312
[2023-10-06 12:47:30] |
User432246 - Posts: 3 |
I cant get the over charts to follow the main chart which is a Vwap based chart in simulation. The order flow chart changes from working to almost blank ones charts are played, main chart continues to play. I have support at the trading group and attempted to resolve but could not. I tried. 1.Aligned Days to Load 2.session Times aligned including set to New York. 3.Press play with play all charts. 4.Tried other saved chart books not effect. 5.Updated to latest Sierra chart. 7.Checked set to SC data delayed data active. 8.Checked trade simulation mode is on. 9.Checked with others if they experiencing this particular issue they are not. Is there anything else I can checked or do to fix this? Thanks in advance |
[2023-10-06 14:16:44] |
Sierra_Chart Engineering - Posts: 17187 |
So you are having an issue with a chart replay?
[2023-10-06 15:24:10] |
correct. Sim delayed trading is fine. Its the replay. unable to sync them so cant use full potential of chart book . thanks. |
[2023-10-06 17:34:21] |
So you are starting a replay from a chart and then another Chart or a Trading DOM is not in sync? First thing we want you to do is to uncheck this option on the Replay window control panel and instead scroll the chart back to start a replay: Replaying Charts: Use Start Date-Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-10-06 17:34:53
[2023-10-07 13:00:46] |
thank for your assistance what you said helped focus the mind. I believe the jump method was incorrect setting as that when it righted itself after testing your suggestion did not work. I able to play back with out the date replay. I will feedback to the teacher at group. Thank-you |
