Date/Time: Wed, 27 Nov 2024 02:33:38 +0000
Fee for the CME data
View Count: 970
[2014-07-18 01:46:42] |
User17064 - Posts: 70 |
Hi SC support, I would like to ask the fee about CME data from SC support 1. Exchange fee to CME data is $94.5 per month. Whatever I choose to request this data in mid or end of the month, I still need to pay 100&, correct? 2. data feed is priced at 35 USD per month for the first connection and 20 USD per month for additional connections (up to 3 connections).
What does it means. Does that mean If I use CME data connection, I need to pay $35 per month, and if I want to add another like CB0T, then I just nned to pay another $20 per month, correct? And this data feed could be paid different based on the days in the month?So totally, if I would like to use CME data start from next month, I need to pay 94.5 + 35 = 129.5 per month right? Thanks! |
[2014-07-18 02:00:40] |
1. Yes, but that price is only if you do not have a trading account or are a professional. There is also this CME group exchange fee available which is much less: Full CME Group (CME, CBOT, COMEX, NYMEX) for Trading accounts: Price 3.25 USD/month. Can only be used by Sierra Chart users with a trading account with one of the supported futures Trading Services.
2. No. These refer to simultaneous connections to the data feed from installed instances of Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-07-18 02:01:06
[2014-07-18 02:32:00] |
Got this. Means share the data feed from different computer with same SC programmer it will pay another 20 per month. Maximum is 3 connections? |
[2014-07-18 03:11:40] |
Maximum is three connections.
