Date/Time: Wed, 27 Nov 2024 00:31:19 +0000
Drawing a line at the middle of candle body
View Count: 340
[2023-10-05 18:43:11]
Presar - Posts: 5
Is there an existing way to draw a line at the middle of a candle body? I've found that "Study Subgraph Reference" and "Auto Retracement/projection" that will do something similar but they use the candle's high and low to determine the midpoint. I want the line to be at the middle of the body instead, which is between the open and close.
Thanks!
[2023-10-05 20:02:33]
Sawtooth - Posts: 4120
Use the Spreadsheet Formula study with this formula in its Formula field:
=(MAX(O,C)-MIN(O,C))/2+MIN(O,C)
Set the Chart Region to 1.
Set the Draw Style to Dash.
Date Time Of Last Edit: 2023-10-05 20:46:51
