Date/Time: Wed, 27 Nov 2024 00:41:06 +0000
Flux sur INDICE HANG SENG US.HSIV23 IMCOMPLETE ET DISPARAISSENT
View Count: 280
[2023-10-05 17:22:58] |
User934880 - Posts: 5 |
je trade en particulier l'indice hang seng et ne peut pas travailler car mes cotations disparaissent au fur et a mesure dans le temps en DAILY ainsit que sur les autres unités de temps . dite moi comment faire pour obtenir des flux stable ou cotation stable sur indice hang seng. Le courtier qui me fournit les flux est CQG avec AMP. y a t'il une veritable solution. Ci-joint le visuel sur ma cotation en daily et H4 Date Time Of Last Edit: 2023-10-05 17:41:12
Capture 2.PNG / V - Attached On 2023-10-05 17:21:22 UTC - Size: 30.08 KB - 62 views |
[2023-10-05 17:42:17] |
Sierra_Chart Engineering - Posts: 17187 |
Translation: I trade in particular the Hang Seng index and cannot work because my quotes disappear as time in Daily as well as on other units of time.
tell me how to get stable flows or stable rating on Hang Seng index. The broker that provides me with the flows is CQG with AMP. Is there a real solution. Attaded the visual on my rating in Daily and H4 We want you to repost an image of the chart, following these instructions only: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) And let us know specifically what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
