Date/Time: Wed, 27 Nov 2024 00:36:11 +0000
DOM Only showing one level
View Count: 343
[2023-10-05 17:13:08] |
Yassinovic77 - Posts: 1 |
Hello, I just activated my account and was going around the DOM to figure everything around. I'm not sure why this is happening, but the DOM level only shows one line. I tried on other ticker symbols, but the volume bid & ask only appears on 1 line as well. I Tried to go to Market depth on chart settings to modify the maximum market depth level and change it to 10, its still not working. Can someone help me please! |
Attachment Deleted. Capture 1.PNG / V - Attached On 2023-10-05 17:07:54 UTC - Size: 84.31 KB - 105 views |
[2023-10-05 17:40:09] |
Sierra_Chart Engineering - Posts: 17187 |
Yes that is correct. There is not market depth data for cash Forex symbols. You need to use futures symbols like 6EZ23-CME Refer to this data feed: Delayed Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
