Date/Time: Wed, 27 Nov 2024 00:23:36 +0000
Edit Brackets for Buy/Sell Stop Orders Directly on Chart
View Count: 378
[2023-10-05 16:23:44] |
Alex Shterenberg - Posts: 9 |
Hello, I am trying to figure out a feature on the charts but have been unsuccessful. I have read many posts and suggestions on this site but have not found what I am looking for and I am hoping I can explain it clearly enough for you guys to understand. I place sell stop orders below the current price and buy stop orders above the current price right on the chart by right clicking the chart and selecting buy/sell stop. When I do this it automatically creates a bracket order with a target and a stop loss. Where can I go to edit those brackets or remove them? When I place the order on the chart DOM it will use the brackets if I selected the use attached orders box and will not use them if the box is not checked. So in summary, I want to place buy/sell stop orders by right clicking the chart and I want to be able to edit the brackets that are set for those orders. Thank You Alex |
[2023-10-05 16:48:47] |
Sierra_Chart Engineering - Posts: 17187 |
If you want to modify the price or quantity of the orders, refer to: Chart Trading and the Chart DOM: Modify Order Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
