Date/Time: Wed, 27 Nov 2024 00:42:27 +0000
Wrong currency value in Chart Calculator and R:R Tools
View Count: 271
[2023-10-05 15:56:46] |
User311344 - Posts: 142 |
What can be the reason of doubling the currency value of 1 tick in Chart Calculator and RR Tools despite correct symbol settings as in screenshot?
CurrVal.jpg / V - Attached On 2023-10-05 15:56:06 UTC - Size: 66.26 KB - 74 views |
[2023-10-05 16:47:21] |
Sierra_Chart Engineering - Posts: 17187 |
It is due to the order quantity for the chart. Reduce the order quantity on the Trade Window: Basic Trading and the Trade Window: Main >> Order Quantity (Quantity) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-10-05 18:59:39] |
Silly me. Thank you
