Date/Time: Wed, 27 Nov 2024 00:24:17 +0000
No data feed Rithmic
View Count: 236
[2023-10-05 15:43:29] |
User426349 - Posts: 2 |
I have noticed that after opening SC there is no data update on my charts. Please help.
[2023-10-05 16:46:15] |
Sierra_Chart Engineering - Posts: 17187 |
Refer to: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart And make sure you are using the correct symbols: Data/Trading Service Connection and Symbol Issues: 1.3. Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
