Date/Time: Wed, 27 Nov 2024 00:25:25 +0000
CTL Up and Down Arrows
View Count: 330
[2023-10-05 14:57:37] |
User98657 - Posts: 327 |
When I hit Ctl Up Arrow, or Ctl Down Arrow it adjusts the width of my renko bars. I see in the documentation where the "Up Arrow" and "Down Arrow" are used to adjust spacing, but I'm using CTL Up and CTL Down arrow and therefore should not be getting the same action. I don't want this to be the case as I want to use those button presses as part of a custom study. Can you please tell me how can I stop them from adjusting the bar width? When you're trading from a keyboard and not using the mouse, the up and down arrows are natural tools to use. Thanks for the help. |
[2023-10-05 18:01:00] |
Sierra_Chart Engineering - Posts: 17187 |
Reset all the keyboard shortcuts back to default. You must have configured these: Global Settings Menu: Customize Keyboard Shortcuts (Global Settings menu) They do not exist by default. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-10-05 18:17:19] |
Your documentation indicates this is a default: Changing Bar Spacing [Link] - [Top] There are several ways to change spacing between the bars or columns in a chart. All of the available methods are explained below. These methods also apply to TPO Profile Charts. Use the Up and Down arrow keys on your keyboard to increase or decrease the chart bar spacing by 1 graphics pixel at a time, respectively. It also looks as though this question may have been asked about a year ago, but I don't see an answer to ThreadID=77696. |
[2023-10-05 19:30:54] |
Those particular arrow keys on their own cannot be changed at all. They are defaulted for adjusting bar spacing. There is no way around this.
[2023-10-05 19:35:01] |
OK. I'll just have to live with it. It's not the end of the world, but I would have to say that was not a great choice. I'd really like to see that made user defined at some point in the future if at all possible. But thanks for looking into it for me. |
