Date/Time: Wed, 27 Nov 2024 00:32:58 +0000
Display decimals from Subgraph using Text Display from Subgraph
View Count: 248
[2023-10-05 12:45:01] |
User846000 - Posts: 27 |
Hi Support, How do I display the decimal places from the subgraphs text display study. I Seem to only round up to nearest whole number? I'm using both of the Text studies "Text Display for Study" and "Text Display for Study from Chart" and neither of them display the decimal places. Thanks Tim |
Text Display from Subgraph not showing decimal points 2023-1.png / V - Attached On 2023-10-05 12:44:32 UTC - Size: 15.17 KB - 67 views What subgraphs should be showing decimal points 2023-10-05 1.png / V - Attached On 2023-10-05 12:44:41 UTC - Size: 23.2 KB - 65 views |
[2023-10-05 18:02:05] |
Sierra_Chart Engineering - Posts: 17187 |
This is controlled with the Value Format setting: Chart Studies: Settings and Inputs Tab >> Value Format Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-10-05 18:02:51
