Date/Time: Wed, 27 Nov 2024 02:22:20 +0000
Strategies won't run in version 1158 and later
View Count: 996
[2014-07-17 19:33:51] |
rwilliams1 - Posts: 346 |
For some reason a simple previous bar breakout strategy that has ran with no problems, simply stopped working in version 1158 and later. It runs fine on 1157 and earlier. I even tried recompiling the strategy in 1158 but it simply will no longer run. Any insights on why this may be occurring? Is it because 1158 and later are still in Prerelease status? Thanks.
Date Time Of Last Edit: 2014-07-17 20:06:53
[2014-07-17 20:25:32] |
Have a look at the information for SendOrdersToTradeService: https://www.sierrachart.com/index.php?page=doc/doc_AutoTradeManagment.php#SendOrdersToTradeService There have been some changes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-07-17 20:25:41
[2014-07-17 23:15:27] |
ejtrader - Posts: 688 |
SC Team - Wondering about the reason for forcing this change. If both parameters ( Global Simulation mode & Sendorders ) needs to be set to same - isn't it redundant to have 2 parameters ( to have them set to same value?). trying to see the use case where it is required to have both parameters - where one would have been sufficient. thanks Date Time Of Last Edit: 2014-07-17 23:16:03
[2014-07-17 23:55:09] |
It is for safety. Without this setting, if you disabled the global Trade Simulation Mode, than any auto trade system that is applied to a chart could then send live orders.
[2014-07-18 00:00:11] |
Got it. makes sense to set this as an input parameter.. Thanks |
