Date/Time: Mon, 25 Nov 2024 12:37:57 +0000
live chart and order fills
View Count: 288
[2023-10-04 16:10:00]
User844787 - Posts: 2
Hi I just connects my charts to AMP and i was wondering if my trades are being filled and setup/link for both my accounts are done correctly.
Is there anyway i can check my order fills etc ?
how do i know my funds from AMP (CGQ) is correctly linked ?
THankyou
Kind Regards
V
[2023-10-04 16:37:49]
If you have Setup Sierra Chart to connect to your CQG account and you have not had any issues with the connection, or when placing orders, then it is working properly.
To be 100% sure, you would have to check with your broker to verify the orders that you have sent through.
[2024-03-04 09:06:06]
I am getting the following errors when opening Sierra charts.
1. Version you are using is no longer supported
2. when installing - maximum number of retries encountered, download incomeplete.
Can you please assist sit as i cannot open and view charts anymore.
Thankyou
Kind Regards
Vandana
Private File
Private File
[2024-03-04 16:41:31]
You need to use the Zip installer. Refer to the information here:
Software Download: Sierra Chart Zip Installer
