Date/Time: Wed, 27 Nov 2024 00:40:44 +0000
[User Discussion] - How to determine candle width (in pixels) in study ?
View Count: 261
[2023-10-04 11:27:35] |
erwinbeckers - Posts: 22 |
I'm using a GDI custom drawing function in my study and i'm trying to draw a rectangle around the current bar To do this I need to be able to determine the candle width in pixels I did find the sc.ChartBarSpacing which gives me the spacing between 2 bars, but I cannot find any documentation on how to get the actual width of the candles regards Erwin Date Time Of Last Edit: 2023-10-04 11:28:30
[2023-10-07 18:49:11] |
ForgivingComputers.com - Posts: 960 |
You could do what the rectangle tool does, draw from the midpoints of the adjacent bars, so your box width will always be twice the sc.ChartBarSpacing. You could also tweak that width to be more or less percentage-wise.
