Date/Time: Wed, 27 Nov 2024 00:41:38 +0000
Question
View Count: 253
[2023-10-04 00:03:59] |
azeem sarwar - Posts: 1 |
Hey How i can find "S&P 500 E-Mini Future" chart in "find Symbol " Section ? what ticker sysmbol i need to find . I m trying with ESU23_FUT_CME but i m not able to find it . Also please check with my current subscrption , can i see "S&P 500 E-Mini Future" data ? |
[2023-10-04 14:58:15] |
John - SC Support - Posts: 36309 |
You have access to the real-time data for the S&P 500 E-Mini futures. The particular symbol you need will depend on your "Current Selected Service". But you can use the "Find Symbol" window to get the correct symbol for your setup. Do the following: - Select "File >> Find Symbol". - Select and open the section for "Futures - CME". - Within that section find the symbol you are looking for. It should start with ES. Open that section. - Select the particular contract you want and then select the button for "Open Intraday Chart" or "Open Historical Chart", depending on what kind of chart you are opening. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-10-04 16:55:14] |
Sierra_Chart Engineering - Posts: 17187 |
We see you are using Interactive Brokers, so the symbol is: ES-202312-CME You can find this in File >> Find Symbol >>Futures-CME Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-10-04 16:55:27
