Date/Time: Wed, 27 Nov 2024 00:43:39 +0000
error on chart - historical donwload skipped
View Count: 207
[2023-10-03 19:57:12]
User984597 - Posts: 1
Hello! I try to connect to the apex account, but I encounter the problem "historical download skipped", that is it does not load my chart up to date, the last day with data being October 2. I have attached the picture with the respective error.
How can it be solved?
[2023-10-03 22:52:33]
Sierra_Chart Engineering - Posts: 17187
Several things:
1. Understand Rithmic historical data:
Rithmic Trading Platform Service: Rithmic Market Data and Support Policy
2. Although you have the Denali data feed active and are paying the CME exchange fee, you are not actually using the Denali data feed real-time or historical data for this reason:
The reason you are not getting real-time data from the Denali Data Feed, and historical data from the Denali Data Feed in the case of when using an external Trading service (Rithmic, CQG, Interactive Brokers), from the CME Group of exchanges is that you activated the *Non-Professional* exchange fees. However, you have not verified in the last month that you have a live, funded, futures trading account, which the CME needs in order to allow you data at the lower priced fees.
Refer to the "Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges" section here:
Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges
Rithmic paper trading or trading evaluator accounts are not considered a live funded futures trading account.
Refer to the following for instructions on how to connect once a month to your *live funded* trading account to qualify for the lower-priced exchange fees:
If you do not have a funded trading account or one with a supported Trading service, then refer to this solution:
Easy Solution to CME Funded Trading Account Requirement
Consider the above solution to avoid this problem in the future.
3. To use the Rithmic historical data you need to enter your Rithmic username and password in the historical data username and password fields in Global Settings >> Data/Trade Service Settings.
However, please be aware of the problems associated with that and the frustrations you will have.
Date Time Of Last Edit: 2023-10-03 22:53:07
