Date/Time: Wed, 27 Nov 2024 00:42:21 +0000
Cannot set bar period value below 10 seconds
View Count: 196
[2023-10-03 17:34:05] |
DaveTrader - Posts: 12 |
If I set the Bar Period Value in the Chart Settings to below 10 seconds, for example 5, it still takes 10 seconds to display a new bar. I have a countdown timer, which then counts to negative. Is 10 seconds the lowest you can go, or am I missing something?
[2023-10-03 17:47:26] |
Sierra_Chart Engineering - Posts: 17187 |
You need to set this particular setting to 1 Tick and re-download the data: Data/Trade Service Settings: Intraday Data Storage Time Unit (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Settings) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
