Date/Time: Wed, 27 Nov 2024 00:29:45 +0000
Teton Order Routing CME
View Count: 255
[2023-10-03 17:24:45] |
cryptoplus - Posts: 5 |
Hi I would like to be sure that I can trade CME markets with my AMP account and the Teton order routing. Everything should be working but please confirm. And also, I want to trade Eurex and I have created a CQG access. Please also confirm that, once I have set up the Data/Trade service for CQG, i will be able to trade Eurex markets with AMP. Thanks |
[2023-10-04 14:26:49] |
John - SC Support - Posts: 36309 |
We do not know if you can trade CME markets. Only your broker can tell you that and control that. But, the Teton Order Routing service does work for the CME Group (and only for the CME Group). So as long as you have the Teton Order Routing setup properly, then it is just a matter of making sure with your broker that you are setup on their end. For CQG you will want to set up a separate installation of Sierra Chart to use CQG. So one installation for Teton another for CQG. Instructions: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
