Date/Time: Mon, 16 Sep 2024 19:09:45 +0000
Minor Bug.: customised keyboard shortcuts are not being updated in menus.
View Count: 291
[2023-10-03 16:43:44] |
User408639 - Posts: 65 |
Moin Moin. Having customised some keyboard-shortcuts, I did see, that the menus do not reflect them, but are showing the old ones. This is a minor one. More interesting would be the capability to resize and search the customd keyboard-shortcuts--window. _Tschüß, __Michael. |
[2023-10-04 14:23:22] |
John - SC Support - Posts: 34450 |
Can you please give us an example of one of these that is not updating?
[2023-10-08 17:22:42] |
Moin Moin. Gladly. Please have a look at the red and orange highlights. _Tschüß, __Michael. P.S.: The procedures within "https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#PostingAnImage" were not aplicable, as.: 1. I had to show open menus, 2. The "Customize Keyboard Settings"-image is modal. Hence, I have to attach an image using windows' screenshots. Hopefull, this is ok. Date Time Of Last Edit: 2023-10-08 17:33:46
New Keyboard-Shortcut not showing in menu.ˮToolsˮ-Menuimag.png / V - Attached On 2023-10-08 17:33:14 UTC - Size: 211.65 KB - 77 views |
[2023-10-09 21:36:32] |
We are not able to reproduce this. When we change the Keyboard Shortcut, the menu updates correctly. Make sure you are selecting the "Assign" button after making the change to specifically change the keyboard shortcut to the new setting. Just selecting OK will not do it. Let us know if this resolves it. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-10-16 12:01:26] |
Moin Moin. I did click the "Assign"-Button. Let me, please proove it using a short video. By the way.: The shortcuts do not appear in the context-menus.: Maybe this would be a nice feature. _Tschüß, __Michael. |
Private File |
[2023-10-17 17:34:32] |
Sierra_Chart Engineering - Posts: 16387 |
We are not able to reproduce this. It is not something we can help with. This is going to be an operating system problem. In your case for changes you will need to restart Sierra Chart.
