Date/Time: Wed, 27 Nov 2024 00:22:30 +0000
Study Subgraph Above/Below as Text Label Decimal Place placement
View Count: 199
[2023-10-03 16:00:07]
Oz - Posts: 50
I have labeled bars using the Study Subgraph Above/Below as Text referencing Numbers Bars Calculated Values.
The labels are correct however I'm getting decimal places where I don't want them.
I have the Numbers Bars Calculated Values set to Percentage with 0 decimal places and still get full numbers to 2 decimal places with the volume.
Please see attached pic.
Is there a way to omit these decimal places.
Many thanks.
Private File
[2023-10-03 16:39:15]
John - SC Support - Posts: 36309
What you are getting is the actual data that is stored for that subgraph. It is then modified for the display based on the settings for the Numbers Bars Calculated Values study.
You would need to modify the underlying data first, then display it as you want it. For example, if you want to multiply the data by 100 and then display it with 1 decimal point, you would us the "Study Subgraph Multiply" study and set the "Based On" to the Numbers Bars Calculated Values study and then set the "Input Data" to the particular subgraph and the "Multiplier" to "100".
Then on the "Study Subgraph Above/Below Bar as Text" set the "Value Format" to "0.1" and then reference the "Study Subgraphs Multiply".
Refer to the following:
Numbers Bars: Referencing Numbers Bars Calculated Values Subgraphs in Alert Formulas
Using the Basic Arithmetic Studies
