Date/Time: Wed, 27 Nov 2024 00:37:42 +0000
Save DOM-Design-Settings as Global Settings.
View Count: 319
[2023-10-03 14:55:33] |
User408639 - Posts: 69 |
Moin Moin. Having Found.: "Setting up a permanent DOM design " I am still struggling to save the Layout of my DOM-Charts as global settings.: 1. If I do check.: "Use Global Settings...." in "NV-DOM.Defaultlayout.Use Global Settings.png" , then it takes some more difficult to read-settings letting it look like "NV-DOM.Defaultlayout.UseD Global Settings.png" . My goal is to save "NV-DOM.Defaultlayout..png"'s settings as the Global Ones. Is this possible. (In "Chart Trading and the Chart DOM: Saving Trade DOM Configuration " I did not find how.). Tschüß, Michael. Date Time Of Last Edit: 2023-10-03 15:00:11
[2023-10-03 14:56:40] |
P.S.: Here are the Screenshots.
NV-DOM.Defaultlayout..png / V - Attached On 2023-10-03 14:56:06 UTC - Size: 46.26 KB - 61 views NV-DOM.Defaultlayout.Use Global Settings.png / V - Attached On 2023-10-03 14:56:12 UTC - Size: 19.26 KB - 63 views NV-DOM.Defaultlayout.UseD Global Settings.png / V - Attached On 2023-10-03 14:56:16 UTC - Size: 49.92 KB - 56 views |
[2023-10-03 14:59:12] |
P².S.: I did see "Save DOM graphic settings ", but it effectively tells me to perform my "local" chart settings globally. Can I just save them globally. Date Time Of Last Edit: 2023-10-03 14:59:51
[2023-10-03 16:08:20] |
John - SC Support - Posts: 36309 |
You can setup the Global Graphics Settings for your Trade DOM and have them as you like. The main thing to keep in mind though, is that the best way to have the same "look" for a Trade DOM is to have one setup as you want it, then duplicate that to create another Trading DOM. Make sure you do not delete all the trading DOMs prior to saving your chartbook. You need to have the Trading DOM open when you save and re-open the chartbook so it will be part of the chartbook. Refer to the following: Using Chart Templates: Changing the Symbol of the Chart / Trade DOM For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
