Date/Time: Wed, 27 Nov 2024 00:30:04 +0000
How to copy VbP peaks and valleys lines to other chart?
View Count: 358
[2023-10-03 06:38:18] |
tokauo - Posts: 32 |
Hi, I would like to automatically copy peaks and valleys from VbP to other charts... I was searching on support board but it is not 100% clear to me, so: Is it possible? If it is not possible directly, is there an overcome (for beginner user)? For example: to use other study to auto redraw lines (on the same chart) from VbP, to be available to others charts from it, etc? Thanks you very much Tom |
[2023-10-03 15:40:31] |
John - SC Support - Posts: 36309 |
There is not a way to get the Peaks and Valleys Lines from a Volume by Price study to another chart except by creating a custom study to do so. Someone may have already created a study that does this, or you can have someone program it for you. Search the Internet to start and see what you can find. Otherwise, refer to the list of programmers at the following link: List of Third Party Sierra Chart Study and System Programmers For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
