Date/Time: Wed, 27 Nov 2024 00:33:20 +0000
cant trade real money
View Count: 396
[2023-10-03 05:07:56]
User431357 - Posts: 27
i cant make a real money trade when im not in simulation mode. when i check my trade log my trades are all sim even when i select no sim
[2023-10-03 15:02:46]
Sierra_Chart Engineering - Posts: 17187
You need to set Sierra Chart to connect to your Trading service. This is controlled through the Data/Trade Service Settings Window:
Who is your broker? And then we will give you the appropriate instructions.
Date Time Of Last Edit: 2023-10-03 15:02:57
[2023-10-03 17:48:10]
teton amp
[2023-10-03 23:01:07]
In this case, follow the instructions here:
Sierra Chart Teton Futures Order Routing: Setup Instructions
Date Time Of Last Edit: 2023-10-03 23:01:55
[2023-10-04 13:06:05]
still not working i swiitched from sc all data service to teton rder routing service . i dont have the exact option in wording that you suggested i click on ?https://www.sierrachart.com/image.php?Image=1696424522264.png
[2023-10-04 13:07:21]
amp brokerage says they have me connected to teton and only sierra charts can figure this problem out?
[2023-10-04 14:15:27]
SC Support - Posts: 1895
Hi User431357, I will give you a quick call to help you with this set-up issue now.
[2023-10-04 14:37:12]
Hi there, I missed you with my call just now, please let me know when I can try you back?
AMP Futures can put you on the Teton Order Routing Service without Sierra Chart's intervention; when AMP Futures has added you to the Teton Order Routing Service, your set-up instructions begin with step #5 here:
Date Time Of Last Edit: 2023-10-04 14:37:55
[2023-10-04 16:18:31]
call? im back ???
[2023-10-04 16:25:04]
Sure, I can call in 30 minutes, would that be ok?
[2023-10-04 16:30:58]
yes
[2023-10-04 17:10:04]
Thank you User431357 for connecting, please let me know when I can call you back?
[2023-10-04 17:25:15]
Follow steps 7 through 10 here:
The problem is you did not set the Clearing Firm setting to AMP. It needs to be set that way.
[2023-10-04 20:35:11]
ready bro
call me
[2023-10-05 15:42:02]
Hi User431357, I can call now? Please let me know.
