Date/Time: Wed, 27 Nov 2024 00:30:21 +0000
Disable space bar choosing the last button in Trade window
View Count: 258
[2023-10-02 22:24:21] |
J DIDDY - Posts: 132 |
How do I Disable the space bar choosing the last button pressed in the Trade window. It seems when i hit the the space bar it 'auto presses' the last button pressed in the trade window, by default, when the trade window is active....even though i have set the space bar for another key command shortcut. How to disable this please??? Date Time Of Last Edit: 2023-10-03 09:54:00
[2023-10-03 15:01:44] |
Sierra_Chart Engineering - Posts: 17187 |
You cannot as this is part of the Windows operating system. However, when you do submit an order from the Trade Window, Sierra Chart does transfer the focus back to the chart. At least this happens when the trade window is attached. So attach the trade window with this command: Trade Menu: Attach Trade Window To Chart Window (Trade menu) That should be a workaround. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-10-03 15:09:42] |
Hmmmm, ok! I need that trade window detached so that doesn't work for me! Thx anyway, I'll just be careful! I'm on a Mac btw! Thx |
