Date/Time: Mon, 25 Nov 2024 17:48:38 +0000
Market replay with real-time updates
View Count: 463
[2023-10-02 22:13:50]
Ifrit - Posts: 51
I'm running Market Replay with the following flags:
Standard Replay
10ms chart update interval
Single Chart
The bid/ask depth is updating in real time.
The candle bodies on the chart are not. They update in a block-like fashion once every 500ms or so.
How do I get market replay to mimic what I saw earlier today with real time order flow, and not updating only once every 1/2 second?
If I increase the speed (to 5x, for example), the candle updates in it's non-smooth, block-like fashion 5x faster, but it is still noticeable.
I can't tell if I did something in settings to screw this up or if it's always been like this. I do not remember it doing this yesterday and can't figure out what I might have changed. I'm trying to get it to be indistinguishable from real-time data that I was witnessing earlier in the day.
Date Time Of Last Edit: 2023-10-02 22:18:28
[2023-10-05 14:23:34]
Sierra_Chart Engineering - Posts: 17174
Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this:
[2023-10-05 23:35:43]
Ifrit - Posts: 51
Tick by Tick was set but didn't solve it.
Turns out Rithmic data is shit. Switching to Teton/CME Order Routing solved it. I'll just do my backtesting/market replay on my brokerage account.
Wish I could use Teton for TopStep but what are ya gonna do?
Your charting platform and order routing service are both leagues ahead of the competition. Keep up the good work.
Date Time Of Last Edit: 2023-10-05 23:36:55
[2023-10-09 20:57:55]
John - SC Support - Posts: 36255
You can not use Teton for TopStep, but you can use the Denali Exchange Data Feed. You just need to have another account with a broker to be able to qualify for the non-professional exchange fees from the CME Group.
In particular, refer to the information at the following link:
Easy Solution to CME Funded Trading Account Requirement
