Date/Time: Wed, 27 Nov 2024 00:44:21 +0000
Marking the Previous day Session High and Low
View Count: 298
[2023-10-02 20:51:29] |
Sergio Anacleto - Posts: 9 |
Subject updated from 'Unable to Replay on a new File new intraday Chart (ESU23-CME).' to 'Marking the Previous day Session High and Low' -------------------------------------------------------------------------------- Hi, I am having troubles with marking the previous day session high and low for the ES-Emini. Here is my chart & settings which show todays session instead of previous session. Can you please assist in getting yesterday session high and low marked correctly. With this do I need to change the *The session start to be 9:30:00 EST, the end - 16:14:59 EST.* Cheers Sergio |
OHLC Chart.PNG / V - Attached On 2023-10-02 20:51:20 UTC - Size: 42.89 KB - 74 views OHLC Settings.PNG / V - Attached On 2023-10-02 20:51:24 UTC - Size: 48.51 KB - 75 views |
[2023-10-02 20:52:30] |
John - SC Support - Posts: 36309 |
Set the "Reference Days Back" to "1". This will then display the previous days OHLC on the current day. Refer to the following: Daily OHLC For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
