Date/Time: Tue, 26 Nov 2024 21:31:06 +0000
Cumulative Volume Delta : unexpected study behavior
View Count: 537
[2023-10-02 20:34:32] |
Brookwood - Posts: 26 |
When using the Cumulative Delta: Volume indicator, switching to the 'rolling' setting causes the last few bars to become gigantic, and the scale to keep increasing to astronomical proportions-- tens of millions and counting when it should generally be in a stable thousands-range. Every now and then it behaves, however, and displays a positive/ negative oscillator-like behavior in a normal range as would be expected. I don't believe this is supposed to happen. The first uploaded image is the expected behavior: https://www.sierrachart.com/image.php?Image=1696310866861.png The second shows the runaway behavior. https://www.sierrachart.com/image.php?Image=1696278734218.png Thanks in advance. [Edited with a new first screen shot as the original one wasn't really relevant]. Date Time Of Last Edit: 2023-10-03 05:33:12
[2023-10-03 18:47:18] |
Sierra_Chart Engineering - Posts: 17185 |
We will determine the cause of this and resolve.
[2023-10-18 15:55:22] |
Wondering if we can have an approximate timeline for this fix. If it behaves the same way, I'll be using it as soon as it's finished. Thanks |
[2023-10-18 16:11:27] |
Update Sierra Chart to prerelease 2558. This should be released in that version. Instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
