Date/Time: Wed, 27 Nov 2024 00:41:25 +0000
software freezes and closes....
View Count: 204
[2023-10-02 19:06:07] |
User285770 - Posts: 41 |
I had two chartbooks, when I added another chartbook, the software started working slowly, after I added another chartbook, the software freezes and closes.... What to do how to fix it? |
[2023-10-02 19:11:05] |
I just want to add that my computer is powerful
[2023-10-03 14:53:56] |
Sierra_Chart Engineering - Posts: 17187 |
First thing we want you to do is to run Sierra Chart in Safe Mode: Sierra Chart - Software Login Instructions: Using Safe Mode And make sure Sierra Chart is up-to-date. Instructions: Software Download: Fast Update And then finally refer to: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.16 - What to do if Sierra Chart is in a frozen state for an extended time due to extended high CPU usage caused by an automatically or m Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-10-03 14:54:13
