Date/Time: Wed, 27 Nov 2024 00:41:02 +0000
Control Bar Buttons - Configure Button Not saving
View Count: 238
[2023-10-02 16:52:31] |
JB01 - Posts: 5 |
Hello, I am trying to use the Configure Button functionality for the buttons on the tool bar, specifically for buttons related to drawings such as rectangle, lines, Fib etc. I might not understand how this function works but from what I understand it does not appear to be working. I am performing the following steps: 1. Right Click on the tool bar button, in this case a rectangle drawing 2. Configure Button 3. Select a Quick Load Template 4. Select Load 5. Select Apply and ok These actions make no changes to the template being applied. |
[2023-10-02 17:49:59] |
John - SC Support - Posts: 36309 |
The steps you are taking are not the correct ones. To modify a Control Bar button for drawings to use a specific Configuration, follow the steps at the following link: Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
