Date/Time: Wed, 27 Nov 2024 00:26:08 +0000
MBO Chart Setings
View Count: 230
[2023-10-02 14:33:07] |
Oz - Posts: 50 |
Hi, I subscribed to MBO data. I'd like to have 1 chart showing the full scope of stacking/pulling of MBO orders while another chart (same symbol) only shows orders > 10 lots? I've tried playing around with the chart settings>>custom symbol settings and editing global settings and then disconnecting and reconnecting but can not seem to get this to work. The settings are changing on both charts when I try to implement this. Is there a way to do this? Please advise. Cheers |
[2023-10-02 17:18:35] |
John - SC Support - Posts: 36309 |
You need to use the "Filtering" options under "Chart >> Chart Settings >> Data Limiting >> Volume Filter Settings". Refer to the following: Chart Settings: Volume Filter (Chart >> Chart Settings >> Data Limiting >> Volume Filter Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
