Date/Time: Wed, 27 Nov 2024 00:26:01 +0000
Help with charts
View Count: 326
[2023-10-02 14:28:15]
User485131 - Posts: 6
I cant seem to make my chart look like theirs. the numbers are all scrunched up and not visible. how do i edit this? i tried to edit the width, i cant seem to get it to display like the one shown in the explanation.
thank you
if anyone knows how to bump it up to make the numbers visible id greatly appreciate it. support pushed it from the ticket to the forum here.
Date Time Of Last Edit: 2023-10-02 14:36:30
imageconfused.png / V - Attached On 2023-10-02 14:27:59 UTC - Size: 41.45 KB - 83 views
imagehow I want it to be.png / V - Attached On 2023-10-02 14:28:10 UTC - Size: 8.79 KB - 80 views
[2023-10-02 15:17:45]
User584084 - Posts: 262
Push the Up Arrow Key multiple times to increase the width of the number bars.
[2023-10-02 15:19:48]
hey, thank you, i did but it still doesnt change the ability to see the numbers. here i increased and decreased and its still hidden. do i need to remove the chart of the candles? open to other suggestions.
thanks!
imagechart.png / V - Attached On 2023-10-02 15:19:06 UTC - Size: 20.52 KB - 76 views
[2023-10-02 15:38:25]
I have the same checked. I can bring it in and the numbers get more clear but its when only one row is shown as attached. i want to see multiple spread out and it doesnt seem to be working. seems to happen with most studies ie the footprint chart. the numbers are all scrunched up, but if i zoom in yes i can see them but its only one. is it possible to move around the screen via dragging like on thinkorswim or trading view without messing up the format? i cant seem to figure it out.
imagechart3.png / V - Attached On 2023-10-02 15:36:51 UTC - Size: 8.15 KB - 81 views
imagechart2.png / V - Attached On 2023-10-02 15:36:54 UTC - Size: 6.72 KB - 81 views
[2023-10-02 15:40:23]
I want to see a wide range of data like displayed as attached and i just cant get it to view. its not the size of my monitor because its huge and i should be able to view all the data id think.
imagehowiwant.png / V - Attached On 2023-10-02 15:40:16 UTC - Size: 8.79 KB - 75 views
[2023-10-02 17:37:40]
John - SC Support - Posts: 36309
Your chart is scrolled to the left so you only have 1 or a few bars showing. You need to scroll so that the bars are displayed across the entire screen so you can then see all the data.
[2023-10-02 17:58:06]
im trying to show that the only way i can view the full number value is if its one column. when its all the data its not showing the numbers or negative delta. as attached.
imagechart.png / V - Attached On 2023-10-02 17:57:43 UTC - Size: 20.52 KB - 79 views
[2023-10-02 18:10:02]
You have to increase the Bar Spacing in order to be able to see the values. Refer to the following:
Working With Charts: Changing Bar Spacing
[2023-10-02 18:36:03]
thnx
