Date/Time: Tue, 26 Nov 2024 18:23:20 +0000
Trading Evaluator service, 2nd instance doesn't display any accounts
View Count: 431
[2023-10-02 14:25:47]
j4ytr4der_ - Posts: 938
Does the trading evaluator service not support multiple instances in some way? I've started a second instance and it shows it's connected, data flows, etc. but it doesn't show any of the accounts, only the sim accounts despite not being in sim mode. Running SC 2540 and for now I can't go newer because of some studies I use.
[2023-10-02 14:31:44]
I stand corrected, data is NOT flowing in the second instance. Historical (intraday) loaded up to the moment the chartbook was opened, but realtime data is not continuing to come down for the second instance, only the main.
Date Time Of Last Edit: 2023-10-02 14:32:09
[2023-10-02 14:43:56]
Data flows for the second instance if I change the primary to use SC Data - All Services instead, and restart the second instance. But I still can't get intraday realtime data to flow to the second instance if I'm on Trading Evaluator.
[2023-10-02 17:24:30]
John - SC Support - Posts: 36300
If you are using two different computers, then this would be the reason you are having this issue. Refer to the information on the Denali Data and multiple instances in the following section:
Denali Exchange Data Feed: Connections
[2023-10-02 20:24:46]
Only using a single PC.
[2023-10-03 15:14:48]
In the instance where you are not having the data working, please get us the Message Log by following these instructions:
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
[2023-10-03 17:39:03]
Here you go, this is for ESZ23. The instructions for copying the message log are a little out of date it seems (there is no longer a button to copy the log). Here is my log (data in the 2nd instance is not flowing):
Software version: 2540 64-bit | 2023-10-03 12:35:47.648
Primary Thread ID: 1964 | 2023-10-03 12:35:47.648
Usage end date: 2024-01-16 | 2023-10-03 12:35:47.648
Enabled for: Advanced Features 2. | 2023-10-03 12:35:47.648
Enabled for: Sierra Chart Historical Data Service. | 2023-10-03 12:35:47.648
Enabled for: Denali Real-Time Exchange Data Feed. | 2023-10-03 12:35:47.648
Enabled for: Delayed Denali Exchange Data Feed. | 2023-10-03 12:35:47.648
Enabled for exchange2: CME (Trading Account Required) | 2023-10-03 12:35:47.648
Enabled for exchange2: CBOT (Trading Account Required) | 2023-10-03 12:35:47.648
Enabled for exchange2: COMEX (Trading Account Required) | 2023-10-03 12:35:47.648
Enabled for exchange2: NYMEX (Trading Account Required) | 2023-10-03 12:35:47.648
Enabled for exchange2: fairx_exchange.data | 2023-10-03 12:35:47.648
Allow Support for Sierra Chart Data Feeds is enabled. | 2023-10-03 12:35:47.648
Current selected Data/Trading service: DTC - Sub Instance | 2023-10-03 12:35:47.648
Custom symbol settings values: enabled | 2023-10-03 12:35:47.648
Chart Update Interval: 50 | 2023-10-03 12:35:47.648
Intraday Data Storage Time Unit: 0 | 2023-10-03 12:35:47.648
Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2023-10-03 12:35:47.648
2023-10-03 17:35:47 Local computer time in UTC | 2023-10-03 12:35:47.648
2023-10-03 12:35:47 Local computer time in SC Time Zone | 2023-10-03 12:35:47.648
2023-10-03 17:32:59 Server time in UTC | 2023-10-03 12:35:47.648
Local computer UTC time and Server UTC time difference: 0 seconds. | 2023-10-03 12:35:47.648
Program path: V:\SC-Development\SierraChartInstance_2\ | 2023-10-03 12:35:47.648
Data Files path: V:\SC-Development\SierraChartInstance_2\Data\ | 2023-10-03 12:35:47.648
OS Version Number: 10.0 | 2023-10-03 12:35:47.648
Locale Setting: C | 2023-10-03 12:35:47.648
DLLs: ChartTradingState_64.dll, emojiTradingTools.dll, gcUserStudies_2499_64.dll, JVCDevstudy_64.dll, JVC_dev_64.dll, jvc_studies_64.dll, Quantum_64.dll, sst_FreeBundle_2273_64.dll, sst_FreeBundle_64.dll, SST_LocalCopier_64.dll, TRG_Free_Studies_64.dll, TWFX_FREE_64.dll, TWFX_FREE_SWS_64.dll, TWFX_FREE_ZZS_64.dll, UserContributedStudies_64.dll, zyp sierra free_2151_64.dll | 2023-10-03 12:35:47.648
Allowed protected custom studies: SST_FreeBundle, SST_LocalCopier, TWFX_Free, zyp_app, zyp_download_TS | 2023-10-03 12:35:47.648
Crash reporter started: true | 2023-10-03 12:35:47.648
File >> Disconnect selected. | 2023-10-03 12:35:51.441
DTC - Sub Instance | Waiting for socket receive thread to end | 2023-10-03 12:35:51.441
DTC Client socket (1) | CloseSocket call. | 2023-10-03 12:35:51.442
DTC - Sub Instance | Disconnected. | 2023-10-03 12:35:51.442
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-10-03 12:35:51.442
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-10-03 12:35:53.435
DTC Client socket (1) | Closed. | 2023-10-03 12:35:53.435
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2023-10-03 12:36:07.057
DTC Client socket (1) | Creating socket. | 2023-10-03 12:36:07.057
DTC Client socket (1) | New receive buffer size: 0 | 2023-10-03 12:36:07.057
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-10-03 12:36:07.057
DTC - Sub Instance | Network connection to server complete. | 2023-10-03 12:36:07.058
DTC - Sub Instance | Starting socket receive thread. | 2023-10-03 12:36:07.058
DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none | 2023-10-03 12:36:07.058
DTC - Sub Instance | Setting DTC encoding to Binary VLS | 2023-10-03 12:36:09.833
DTC - Sub Instance | Sending logon request message. | 2023-10-03 12:36:09.833
DTC - Sub Instance | Received logon response. | 2023-10-03 12:36:09.841
DTC - Sub Instance | Server Name: SC DTC Server. Build=46900. | 2023-10-03 12:36:09.841
DTC - Sub Instance | Server protocol version: 8. Client protocol version: 8 | 2023-10-03 12:36:09.841
DTC - Sub Instance | Successfully connected. Connected to SC DTC Protocol server. Service=scdataallservices|SymbolSettings=scdataallservices. | 2023-10-03 12:36:09.841
DTC - Sub Instance | Trading is supported. | 2023-10-03 12:36:09.841
DTC - Sub Instance | Order cancel and replace is supported. | 2023-10-03 12:36:09.841
DTC - Sub Instance | OCO Orders supported. | 2023-10-03 12:36:09.841
DTC - Sub Instance | Bracket Orders supported. | 2023-10-03 12:36:09.841
DTC - Sub Instance | Connected to server complete. | 2023-10-03 12:36:09.841
Triggering next historical data download in queue. | 2023-10-03 12:36:09.841
No download requests in the queue to start downloads for. | Number times prior message previously added: 3 | 2023-10-03 12:36:09.843
Using symbol data fast lookup vector | Number times prior message previously added: 3 | 2023-10-03 12:36:09.863
DTC - Sub Instance | Starting real-time market data updates for: ESZ23. ID: 1 | 2023-10-03 12:36:09.863
DTC - Sub Instance | Requesting security definition data for: ESZ23. ID: 1 | 2023-10-03 12:36:09.863
Added historical Intraday data request for ESZ23 to the queue. | 2023-10-03 12:36:09.863
Intraday data recording state for symbol ESZ23 is set to download 'Pending'. | 2023-10-03 12:36:09.863
Triggering next historical data download in queue. | 2023-10-03 12:36:09.863
Delaying start of download for ESZ23. | 2023-10-03 12:36:09.868
DTC - Sub Instance | Received security definition for symbol ESZ23 | 2023-10-03 12:36:13.893
HD Request # 3 | Downloading Intraday chart data for ESZ23 to the file ESZ23.scid. Service: cme | 2023-10-03 12:36:18.362
HD Request # 3 | Download start date-time: 2023-10-03 12:34:41.000000. File last date-time: 2023-10-03 12:34:41.440000 | 2023-10-03 12:36:18.363
HD Request # 3 | Using server: ds23.sierracharts.com port 10149 | 2023-10-03 12:36:18.363
Socket (2) | Creating socket. | 2023-10-03 12:36:18.363
Socket (2) | New receive buffer size: 0 | 2023-10-03 12:36:18.363
Socket (2) | Connecting to IP: 142.215.17.190. | 2023-10-03 12:36:18.363
HD Request # 3 | Setting DTC encoding to Binary VLS | 2023-10-03 12:36:18.491
HD Request # 3 | Sending historical data logon request message. | 2023-10-03 12:36:18.491
HD Request # 3 | Requesting Intraday data. Start date-time: 2023-10-03 12:34:41. Record interval: 0. Symbol: ESZ23 | 2023-10-03 12:36:19.037
HD Request # 3 | Decompressing data. | 2023-10-03 12:36:19.104
HD Request # 3 | Receiving Intraday data for ESZ23 starting at 2023-10-03 12:34:41.440000 | 2023-10-03 12:36:19.234
Socket (2) | CloseSocket call. | 2023-10-03 12:36:19.236
Socket (2) | Shutdown started. Waiting for graceful close. | 2023-10-03 12:36:19.237
Historical data download thread signaled to stop. | 2023-10-03 12:36:19.237
HD Request # 3 | Timestamp of first Intraday data file record written: 2023-10-03 12:34:41.967000. | 2023-10-03 12:36:19.237
HD Request # 3 | Received 3718 Intraday data records from 2023-10-03 12:34:41.440000 to 2023-10-03 12:36:16.255002 (94.8 seconds. Delay: 3.0 seconds) and wrote 3717 records for ESZ23 | 2023-10-03 12:36:19.237
HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2023-10-03 17:36:16.255002 | 2023-10-03 12:36:19.245
HD Request # 3 | Completion time: 1s. | 2023-10-03 12:36:19.245
HD Request # 3 | Intraday data download complete for ESZ23. Unique request ID: 3 | 2023-10-03 12:36:19.245
Removing historical data download ID 3. | 2023-10-03 12:36:19.245
Real-time Intraday chart data file updates started for ESZ23 | 2023-10-03 12:36:19.245
Intraday chart data file opened for ESZ23 | 2023-10-03 12:36:19.245
HD Request # 3 | Enabling Intraday chart updating for symbol. | 2023-10-03 12:36:19.245
Triggering next historical data download in queue. | 2023-10-03 12:36:19.245
No download requests in the queue to start downloads for. | 2023-10-03 12:36:19.245
Socket (2) | Socket gracefully closed by remote side. | 2023-10-03 12:36:19.297
Socket (2) | Closed. | 2023-10-03 12:36:19.297
[2023-10-04 14:30:13]
The log does not show any issues, in fact it shows that the data should be downloading just fine.
Please go through the items at the following link to see if any of the following may be the issue:
[2023-10-04 15:30:33]
Looking through that list, I don't think any of those items apply here. Time & Sales is completely blank, and the trade window shows only sim accounts despite not being in sim. I opened a 3rd instance to check it as well, and still nothing. Only the main instance works, and it seems to work totally fine. I get no error messages, no indications of any kind as to what's going on.
[2023-10-04 15:38:56]
OK hang on, finally found this line in the message log... only appears once.
UDPListener (1716). Port 22904 | Error binding to UDP port: 22904. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2023-10-04 10:21:01.237
[2023-10-04 16:24:32]
That error you are showing in the last post is not an issue. It comes up if you are running multiple sub-instances, but is not an issue.
When you open the sub-instance, are you getting the missing data filled in and then not getting any new data?
The Trade Window will show only Sim accounts if your Main Instance is in Simulation Mode.
[2023-10-04 16:46:43]
Yes, historical data fills in any time I disconnect and reconnect.
Secondary instance is showing sim accounts, primary instance is NOT in sim. I am actively trading in one of my accounts under the Trading Evaluator right now in instance #1, but only see Sim accounts in instances >= #2.
[2023-10-09 20:18:25]
Our apologies - this thread got passed over.
If you are still having an issue with the data in a sub-instance, then please get us the Message Log again by following these instructions:
[2023-11-01 14:00:30]
Just to update, I haven't had time to look into this further but still intend to at some point. I'm stuck on version 2540 for the foreseeable future however due to newer versions breaking compatibility with some studies I need. But I will surely update when I have something new/different to report on this. Thanks.
