Date/Time: Wed, 27 Nov 2024 01:58:08 +0000
sierra / jig saw difference
View Count: 850
[2023-10-02 13:38:18] |
tradewerx - Posts: 6 |
hello, i recently switched to sierra from jigsaw. i have nnoticed the "recent trades" column is different between the two. i have both chart update intervals set to 200ms. any reason why there is such a descrepancy between the two? i have attached a screen shot (jigsaw on the left, sierra on the right). i have spoken to some fellow traders and they dont have an answer. any help is appreciated.
jigsaw.vs.sierra.png / V - Attached On 2023-10-02 13:34:59 UTC - Size: 72.19 KB - 257 views Attachment Deleted. |
[2023-10-02 14:09:36] |
Sierra_Chart Engineering - Posts: 17190 |
There are these settings which affect of those market data columns: Global Trade Settings Windows: Reset Recent Bid/Ask Volume on Bid/Ask Change (Global Settings >> Chart DOM Settings >> Other >> Other Settings) Global Trade Settings Windows: Recent Bid Ask Volume Timeout in Milliseconds (Global Settings >> Chart DOM Settings >> Other >> Other Settings) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
