Date/Time: Wed, 27 Nov 2024 01:34:38 +0000
New account
View Count: 184
[2023-10-01 23:40:01] |
User699896 - Posts: 1 |
I would like to order software that shows the order flow and bars, showing numbers of the amount of buys and sells. Which software package do I buy? Is there a trial period offered? Thks.
[2023-10-02 08:31:01] |
Sierra_Chart Engineering - Posts: 17189 |
You would need Service Package 5 or 11 depending upon if you need real-time futures or stock data. Do you need real-time data and for what particular exchanges? Yes you have a trial currently. We have activated your trial. For Sierra Chart pricing, refer to this page: Description of Service Packages and Pricing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
