Date/Time: Wed, 27 Nov 2024 01:44:08 +0000
TPO profile problem
View Count: 246
[2023-10-01 23:13:44] |
User350195 - Posts: 34 |
TPO profile keeps recalculating data. Please see the attached video. ES current contract. Thanks. Date Time Of Last Edit: 2023-10-02 01:13:11
Private File Private File |
[2023-10-02 08:43:56] |
Sierra_Chart Engineering - Posts: 17189 |
This is not a problem. With the particular settings you have it is going to continuously recalculate. You are using a less common configuration. It is best to set this input: Time Price Opportunity (TPO) Profile Charts: Number of TPO Profile Periods To Multiple Profiles and have them be based on 1 Week. And then simply load less data into the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-10-02 15:05:02] |
This is a workaround the issue not really solving it.
