Date/Time: Wed, 27 Nov 2024 00:27:59 +0000
Setting defaults for Chart Settings
View Count: 580
[2023-10-01 19:36:26]
WarEagle - Posts: 73
There are several Chart Settings that I use on every new chart and would like to be able to set these by default.
Is there any way to set "Include Columns With No Data" and "Include Saturday-Sunday Bars For Daily Charts" to "Yes" so that I can always have calendar days?
Is there a way to set the number of forward columns to something other than 150 by default?
Even just a "Save as Default" option in the Chart Settings would work.
[2023-10-01 19:52:59]
Rui S - Posts: 190
Maybe this will do what you need?
https://www.sierrachart.com/index.php?l=doc/UsingChartTemplates.php#SettingDefaultChartSettings
[2023-10-01 20:13:57]
Thanks, but that is only for three of the chart settings and does not include the ones I need.
[2023-10-02 16:38:14]
John - SC Support - Posts: 36309
You need to create a "Template" chart and have it set the way you want and then duplicate that chart and change the symbol to get the new chart. Refer to the information here:
Using Chart Templates: Duplicating Charts / Template Charts
[2023-10-02 17:03:15]
Thank you for the suggestion. I've done this in the same chartbook, but would like a way to do that with a fresh chartbook when nothing else is open. I'd prefer not to have to open a separate chartbook just to duplicate a chart off it...that takes just as long as changing the settings.
Could these settings be made available in the list of custom toolbar functions where we could set a button to change the settings like what is available for so many other things?
[2023-10-02 17:51:01]
The only option is to duplicate the chart from another chartbook.
