Date/Time: Wed, 27 Nov 2024 00:23:06 +0000
Volume/Sec in Numbers Bars Calculated Values difficult to read
View Count: 379
[2023-10-01 14:21:03] |
mojsterr - Posts: 26 |
Hello. When I add this Subgraph, the numbers presented are shown in a way that is very dificult to read. Can this somehow be changed? Added a screenshot for reference. https://www.sierrachart.com/image.php?Image=1696169874780.png EDIT: I have found the "Use Default Nuber Formatting for All Subgraphs" option and it got rid of decimals, so I guess that's that. EDIT2: It's weird it only shows such small values, though. I've seen people showing stocks or futures, with some huge values, but forex EURUSD has small ones like these. Date Time Of Last Edit: 2023-10-01 17:20:05
[2023-10-02 16:19:13] |
John - SC Support - Posts: 36309 |
We are not sure if you are asking about the number of decimal places or the values themselves? With regards to the number of decimal places, the FOREX data has an underlying format that is the 5 decimal places, which is why it is displaying as such. With regards to the numbers themselves, they are much smaller than Futures simply due to the amount of trading. There is less trading occurring on the FOREX, which is why the Volume/Sec values are smaller. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
