Date/Time: Wed, 27 Nov 2024 00:39:35 +0000
Market Replay
View Count: 281
[2023-09-30 18:57:51] |
Ifrit - Posts: 51 |
Market replay freezes when I hit either the Stop or seek buttons. I have to "end task" in Task Manager to quit Sierra Chart because it does not recover. If I let it run without touching it then it runs fine and without any problems. I have attached an image of the problem. Nothing else on the computer is running. RAM and CPU usage not maxed out. 2 DOMs and 2 Charts with a few studies on either. Nothing serious. Date Time Of Last Edit: 2023-10-01 20:04:47
Market replay freezing.png / V - Attached On 2023-10-01 17:50:19 UTC - Size: 93.75 KB - 73 views |
[2023-10-02 16:02:01] |
John - SC Support - Posts: 36309 |
We wonder if you have a problem with a particular chart. Please try running the Replay with just a single chart at a time, and see if you have the same problem with all charts, or if there is a single chart that causes you an issue, and if so, attach that chart to this thread for us to take a look at it by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-10-02 16:02:19
[2023-10-02 18:04:11] |
Ifrit - Posts: 51 |
Problem solved. RAM died today. Was on its way out I suppose. New RAM fixed the problem. Thank you for the response. Never needed to try running a single chart. Date Time Of Last Edit: 2023-10-02 21:22:38
