Date/Time: Wed, 27 Nov 2024 02:36:17 +0000
Bar length in info field
View Count: 906
[2014-07-17 05:58:12] |
AKR - Posts: 523 |
if this is easy it would be great if you could add the length of a bar in points (absolute value of high minus low) in the little info field on the top left corner of the main window. in addition to O: H: L: C: (or can I do this myself?) I really often need the distance a bar made and always need to calcualte myself ... |
[2014-07-17 08:08:38] |
Use the Bar Difference study.
[2014-07-17 08:24:46] |
AKR - Posts: 523 |
hm. but this would mean I have to use some screen space only for that. I would prefer scrolling over charts and seeing it. also I dont need it for each bar, just sometimes you quickly want to see eg. the range of a day. anyway, just a question, I can live without but would be a nth |
