Date/Time: Wed, 27 Nov 2024 01:39:39 +0000
spread trading
View Count: 228
[2023-09-30 09:41:08] |
User19991027 - Posts: 12 |
I want to see the spread of es futures, which is the difference between the main contract and the contract of the next period. Is there a way to obtain continuous data? Another question is, when looking for symbols, what is the difference between those with "FUT" and those without?
[2023-10-02 15:42:49] |
John - SC Support - Posts: 36309 |
If there is an exchange traded spread for this, then refer to the following documentation for how pull up the data for exchange traded spreads: Real-Time Exchange Data Feeds Available From Sierra Chart: Exchange Traded Spreads Otherwise, you can create a chart for the spread using the "Custom Calculated Symbols". Refer to the information here: Custom Calculated Symbols For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
