Date/Time: Wed, 27 Nov 2024 01:53:56 +0000
[Programming Help] - Studies : volume at price threshold alert V2
View Count: 327
[2023-09-30 09:12:24]
User290288 - Posts: 1
Dear,
I am new at Sierra Chart and i would like to ask about stack imbalance highlighted.
It is possible to take-off only single or 2 stacked imbalance extension lines, but just show 3 stacked imbalance as draw extension line with transparent range?
I do not want stack imbalance show as yellow box highlighting (default) around group of adjacent alert
Thank you
[2023-10-02 15:39:51]
John - SC Support - Posts: 36309
You can turn off the highlighting of the stacked imbalance by setting the subgraphs for "Adjacent Alert Highlight Bottom/Top x" to "Ignore".
But there is not a way to turn off certain extension lines. You are given a few options for what extension lines to draw for an Adjacent Alert in the Input for "Draw Extension Lines", but that is all.
But, if you only want to see extension lines when you have at least 3 stacked imbalances, then be sure to set the Input for "Highlight Adjacent Alerts Minimum Group Size" to 3.
All of the information for the above can be found at the following link:
Volume at Price Threshold Alert V2
