Date/Time: Wed, 27 Nov 2024 01:56:23 +0000
Charts
View Count: 238
[2023-09-29 17:18:50]
User423634 - Posts: 23
Thank you, I'm running into a problem. I have 2 charts and one of them is detached, when i draw a line on one chart it copies over to the next but when i draw that same line on the detached chart first it doesnt show up on the other chart.
[2023-10-02 15:05:46]
John - SC Support - Posts: 36309
You do not have the one chart setup to copy drawings from the detached chart, but you have it the other way. You would need to set it up for both if that is what you want. Refer to the information for copying drawings between charts at the following link:
Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu)
