Date/Time: Wed, 27 Nov 2024 02:26:58 +0000
ECIVwap Anchor
View Count: 244
[2023-09-29 09:52:21]
User928103 - Posts: 11
Dear Staff,
I make extensive use of a Custom Study called ECIVwap anchor.
To recall this Study, I open the Analysis drop-down menu and select it.
This mode is not very practical therefore, I ask you if it is possible to create a button in the Tool Bar.
I would ask you to indicate the path to me so that I can add it to the Tool Bar buttons.
Thanks in advance,
mrk bttl
[2023-09-29 10:38:41]
User431178 - Posts: 543
First, make a study collection that has only the study you desire.
Study Collections
Then, add a control bar button that is linked to the study collection.
Control Bar: Control Bar Study Collection Buttons and Keyboard Shortcuts
[2023-09-29 13:36:03]
Sierra_Chart Engineering - Posts: 17190
Yes the post #2 is the correct answer.
