Date/Time: Wed, 27 Nov 2024 02:34:05 +0000
Frequent data disconnection
View Count: 230
[2023-09-28 23:15:08]
User347921 - Posts: 39
I'm using Rithmic data feed (Level 2) through TopStep and have used Sierra Chart up the 26th Sept. normally. I didn't connect to SC for two days and now the data feed disconnects almost every minute. I'll send you a Log file.
Thank you.
[2023-09-29 14:31:37]
Sierra_Chart Engineering - Posts: 17190
We cannot help at all with this:
DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2023-09-29 01:14:08.631 *
We recommend trying the Trading Evaluator service and see if you notice the same problem:
Simulated Futures Trading Service
If not, the connectivity issue would be specific to Rithmic.
