Date/Time: Wed, 27 Nov 2024 02:35:53 +0000
Different session start times for different time frame within a single chart book
View Count: 229
[2023-09-28 17:55:44]
ElsonJr - Posts: 5
Hi Sierra,
Just want to check if it is possible to set different session start times for different time frame within a single chart book? It seems like the only possible way is way is to have a chart book for each individual time frame..
Example
4h time frame session start time to be 22:00:00,
3 hr time frame session to be 21:00:00
2 hr time frame to be : 21:30:00
Above all to be in a single chart book.
[2023-09-28 18:05:54]
John - SC Support - Posts: 36309
A "Chartbook" is a collection of charts. So you can certainly have 3 different charts each with a different time frame and each with different Session Times. Any setting that is done through "Chart >> Chart Settings" is a per chart setting.
If you are asking for a way to do this on a single chart, then no - it can not be done. You can only have a single time frame per chart and you can only have a single set of Session Times for a chart.
