Date/Time: Wed, 27 Nov 2024 02:45:17 +0000
How to save current set-up
View Count: 218
[2023-09-28 17:25:50]
User762680 - Posts: 7
I am ordering a new computer and want to transfer my SC set-up to it.
Is there a way to save our personalized chart's through an email, or flash drive or????
My current computer is making weird noises and I hate to not have everything saved in case of a computer crash.
Thanks in advance
[2023-09-28 18:02:45]
John - SC Support - Posts: 36309
Refer to the information at the following link:
Transferring Sierra Chart Settings and Data From Existing Installation to New Installation
The first section is the easiest method by copying certain files that you will need. You should also copy the Market Depth data (see the particular section for that in there). But you can copy everything and update some paths if you want to do it that way, in which case look at the other options in that section.
