Date/Time: Wed, 27 Nov 2024 01:42:29 +0000
Small Pixel amount scaling factor set to high
View Count: 355
[2023-09-28 02:24:05]
User707173 - Posts: 2
I can not see GUI menu to set to the pixels smaller because the pixel amount is set to high
[2023-09-28 13:37:04]
John - SC Support - Posts: 36309
We are not understanding the issue.
If the "Small Pixel Amount Scaling Factor" is set too high, then you can lower it in "Global Settings >> Graphics Settings >> GUI".
The information for this setting can be found here:
General Settings Window: Small Pixel Amount Scaling Factor (Global Settings >> General Settings >> GUI >> Application GUI)
[2023-09-28 13:53:19]
Sierra_Chart Engineering - Posts: 17189
If you provide us a screenshot of the General Settings window we could understand this better. If you still have an issue that is.
[2023-09-29 21:55:13]
When I made the pixel size to large it made the GUI window menu huge so I'm not able to see the pixel setting to set them back to the default setting because they are off the screen
[2023-10-02 09:04:45]
What if you maximize the General Settings window? Can you then see the Value column?
We will see about adding a command to reset the column widths to default.
