Date/Time: Wed, 27 Nov 2024 01:54:54 +0000
footprints
View Count: 249
[2023-09-27 20:17:02] |
User484298 - Posts: 1 |
I want to make my footprints look like the image I'm sending, I'm new to the software too
Date Time Of Last Edit: 2023-09-27 20:17:56
footprint chart.PNG / V - Attached On 2023-09-27 20:10:30 UTC - Size: 479.64 KB - 92 views |
[2023-10-02 08:53:40] |
Sierra_Chart Engineering - Posts: 17190 |
Get started here: Numbers Bars: Step-By-Step Instructions There are a lot of options. Best to go through them carefully and configure the chart as you require. One thing that we see is that it looks like that chart is using 2 Numbers Bars columns. One of them looks like it is showing the difference between Ask volume and Bid volume and another one is showing Total volume. We also see a volume profile on that chart. To add that, use the Volume by Price study: Volume By Price Study We have no idea what study is at the bottom of the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-10-02 08:54:39
